Jump to content
Problem with onObjectValidate on a Related Field
onobjectvalidate related field
  • Please log in to reply
20 replies to this topic
#21 LaRetta   Lifelong FM Student
LaRetta
  • Members
  • 10,234 posts
  • LocationOregon
  • FM Application:13 Advance
  • Platform:Mac OS X Mavericks
  • Time Online: 252d 14h 31m 51s
Posted 29 January 2014 - 06:09 PM
in reality, the serial number is unique to every box that we have built, therefore, the boxes table currently contains about 900 entries.  Is it unreasonable use a value list that large?
Value Lists, even if using pop-up menus and drop-down lists, work best for sets under 50.  Since this is a LineItems portal on an Invoice, I would probably include another field such as Model which can filter the list for you.  If you first select the Model, you can use conditional value list to then display only boxes for the model specified.
Another option is to provide a portal in a popover or window.  You can filter the portal in similar fashion.
  • 0
Each assumption is an educated guess, a likely condition or event, presumed known and true in the absence of absolute certainty.
Also tagged with one or more of these keywords: onobjectvalidate, related field
FMForum Advertisers
