Difference between two revisions of the same record
I've a small task that I don't manage to do: find the difference between two revisions of the same record.
I've different status for the same records.
The typical path is:
  •     Creation of the records – Status is set to  "created" and version to 1
  •     When the user is done a button allow the status to change to "validated" – with the security parameter this version is not editable any more
  •     When a revision is needed I've another button that duplicate the record and set the revision to 2 and change the status to "under revision"
  •     Again when the user is done a button allow the status to change to "validated"
  •     … for as many revision as it takes
I'd like to find a simple method to know the changes made between two validated versions.
I thought of comparing the two records and return the fields (with the values) that have changed. Does anyone have a solution? Is there a better way?
I don't want a full audit trail as I only need the changes made between the two validated records.
Thanks for your help
