Using ftp_rename deletes rather than moves
UPDATE: I was using the wrong path. My bad. It works. Doesn't move but copies so I then delete it after moving.
I'm trying to move a file that is in the Root (so the path is just the file name) to a folder in Root called "Moved". When I use FTPEEK_Rename with (" filename.pdf";"/Moved/filename.pdf") it deletes the file and it never appears in Moved. I tried this and  (" filename.pdf";"Moved/filename.pdf") and same thing.
Any suggestions?
Using FMP 19 on MacOS 10.14
Edited by Ddoughtie
Update
