Issue connecting to SQL DB using MBS
I have been attempting to connect to a SQL database on my network using Monkeybread Software and each time that I attempt to do it I have encountered the same error, which I have attached here. I have set up an ODBC connection as well as made sure that I had the names correct, however I have gotten the same error message each time. Thank you for your help.
The issue has been worked around, due to the device I'm working on (the Surface Pro X) did not take a ODBC connection I was attempting to make.
