printing problem on laser printer
Hello,
Using FileMaker Developer 5.5 I have several layouts with multi-line text fields. I set up 5 pixel left and right margins for the fields. The text displays correctly in Preview mode and prints correctly on my HP OfficeJet printer at home. The printing problem is at work using a HP LaserJet. It ignores my indents and prints the text right up to the edge of the field and sometimes beyond the right field boundary. Any suggestions for how I could correct this? Thanks.
No definite answer, but here are some things to check. Do you have fixed margins on your layout? Do you use a script for printing the report (with the wrong page setup defaults)? When you have the laserjet selected as your printer, do a page setup and then go into layout mode. It should show where the printer's margins are. This may help to narrow down the source of the problem.
