Import Picture Script Problem
Help..!!! I have this quirky problem when I run Import Picture from a script; it [usually, but not always] opens the Sound file first. Then I have to cancel that and it will bring up the Pictures folder dialog box to select. This only happens in my script. If I use the Import Picture option from the menu, it works just fine.
What I'd really like to do is have the script always open a pre-defined folder where the images will be maintained and then let the user select the image.
Also, since this will be a bound solution and eventually ported to the MAC (I'm on Windows XP), the pointer to the "picture folder" would have to be relative to the solutions folder, so it will always be found.
Or, at the very least, NOT pop up the sound file!!
Also, I don't want to use costly plug-ins.
Thanks.
Ellen,
Totally wierd.... did it to me when I was testing an answer for you. Windows XP with FM5.5.
Anybody have an idea?
