Calculated replace problem
I am trying to replace quotation marks in fields. The "substitute" function does not appear to work with this string:
Substitute(City, """, "")
I want to substitute a single quote mark in the City field with no character. Filemaker keeps telling me that I need an additional quote mark. I think it's reading the text I want to replace (a quote mark) as a quote mark used to surround text.
Any ideas?
ok, i had this problem once as well.. what i did was this.. i made a global field, and called it quote, then populated that field with a quotation mark ("). then i made my substitute field look like this.
Substitute(City, quote, "")
oh yes, this works best if you turn off smart quotes. (go to document preferences and uncheck "use smart quotes".)
[ March 26, 2001: Message edited by: bman ]
  • 2 years later...
hey, friend, I've tried that.. but it didn't work...
may be i'm not doing the things well,...
i just want -in general- to write ascII simbols into a chain of string without filemaker tells me that I can
