March 14, 200422 yr Hello I have two files - One called dealer list which has a picture of every dealer person. I have a second file called registration and when I type in a name that matches a name in the between the two files ( in a relationship) It is supposed to display the photo in the "registration" file but it won't do it. can anyone tell me what I might be doing wrong here. It seems simple enough but it just is not working. thanks stan Version: v6.x Platform: Mac OS X Panther
March 15, 200422 yr Is the relationship established by the names in both files? Does the portal represent that relationship? Is the container field in the portal of that relationship? If yes, it can be a display problem on Mac OS Panther, and you will have to do the test on another platform.
March 15, 200422 yr Make sure the field in the portal uses the same relationship as the portal. If the relationship has Sort Records turned on, make sure all the fields specified to sort by exist. Can you display any other fields to verify that the portal is working properly?
