Previously Working Script Does Not Work in FMP v7
Hi Guys, having a problem with a very simple script that will not work in FMP7 whereas it worked fine in FMP6;
If(IsEmpty(Invoice Paid Date);Int(Get(CurrentDate)-Invoice Date);0)
If an invoice has NOT been paid, the above should return a value equal to the amount of days since the invoice was raised. If the invoice has been paid it should return a value of '0'. In FMP6 the script read as If(IsEmpty(Invoice Paid Date);Status(Status(CurrentDate)-Invoice Date);0) and if the invoice date was also blank then the calculation field would remain empty, however, in FMP7 if the Invoice Date field is blank the sript returns a series of numbers such as '731690'.
Can anyone shed any light on why FMP7 messes this up and what I can do to correct the problem? Cheers.
FileMaker Version: 7
Platform: Mac OS X Panther
Try:
If(IsEmpty(Invoice Paid Date); If (not IsEmpty(Invoice Date); Get(CurrentDate)-Invoice Date); 0 )
Nested Status functions are not supported in FM7, and I don't think Int() is the what you want instead.
Excellent, worked perfectly. Thanks v much!
PS: What is the difference (or reason for using)
instead of
[FieldName]=""
I tend to use the latter in calculations especially If statements but wondered if I should be using the IsEmpty syntax?
Cheers
Nelly->
FieldName = "" will only work reliably for text fields. A good programming practice is to always use IsEmpty(), it's guaranteed to return what you expect. I used to use = "" and wondered why certain calcs blew up...
