April 22, 200421 yr I have never used Developer, but if it could solve this problem i will buy it. I would like to use the feature in FMP7 thats called Insert File, but i dont want to save as a reference, i would like to save it inside of the database. My problem is that i would like to open the file "inside" of Filemaker without exporting the file. Because i have never used developer i now wonder if there is any functions in FMPDev7 that could solve my problem? I am not interested in a plug-in, i only want to be able to open the file i have inserted directly from FM. Regards loogi FileMaker Version: 7 Platform: Windows XP
April 23, 200421 yr Developer won't do anything extra for you on this one. Some file formats are viewable (not editable) in FM. Formats like EPS, TIF, GIF, JPEG... for example. What format are you working with?
April 24, 200421 yr Author i would like to insert word, excel, visio and cad-files. Are you sure that they are viewable? I cant remember that it works with jpeg.. I posted this question in a swedish forum (im swedish), and they were talking about that this function will be fixed in the next upgrade of FMP. Then it should be possible to open an embedded (inserted) file from filemaker. Has anyone heard of this, and when does this upgrade come?
April 26, 200421 yr The files you've listed above would not be viewable in FileMaker. I have created a solution where in addition to importing a file format that could not be viewed in FileMaker I also imported an accompanying GIF, TIF or JPG file to act as a preview of the non-viewable file I was importing. This may or may not be suitable in your situation.
