Substitution scripting problem, NEED help please!
I am running a script to do multiple substitutions of text in a global field running fmp 7. I was told that it could be done but I have been unable to get it to run.
My script is:
Go to Record/Request/page[First]
loop
Set Field[completed_template; Substitute(template; "the_item_name"; item_name)]
Set Field[completed_template; Substitute(template; "the_item_id"; item_id)]
Set Field[completed_template; Substitute(template; "the_item_case"; item_case)]
Go to Record/Request/Page[Next; Exit after last]
end loop
item_name, item_id, item_case, completed_template are all text fields
template is text global
The script runs but only substitutes every occurace of "the_item_name" for item_name in the global field and does not substitute either of the two other substitution fields.
Can anyone see what the problem is? Where am I going wrong? Thanks
duplicate post - answered in FM7 subforum.
