Problem with Script for Importing and Exporting
I have some scripts to Import and Export data to Temp files. The script imports/exports data and saves as Tab file on the desktop. Another script would be used to put the data back into FMP.
The script used to work fine untill now. Recently our systems were upgraded to Win 2k and they dont work now. Please HELP
It is because our beloved Microsloth overlord has * moved * the darned Desktop!
It used to be in:
C:Winntprofiles[your user name here]Desktop
It is now located in:
C:Documents and Settings[your user name here]Desktop
You may have to respecify where to save & read your TAB files, in your scripts.
Thanks Carey. But the question here rises is that the server where i have the database is on WinNT and our personal systems are win2k.
Is there a solution to this.
quote:
It used to be in:
