Images in Footer problem!
Hi
I have a layout with Header,Body,Footer and Title Footer. I'm trying to isert a picture to be printed on this layout placed inside the Footer area. It just doesn't print it! I can see it in "browse mode" but not in "preview mode" and so doesn't print it at all.
Any hints? Images can't be placed in the footer?
Any reply is appreciated.
Does the image preview/print if it's in the Header or Body part?
Check if "Do not print selected objects" is selected in the Sliding/Printing options for that object.
Yes the image shows in the header and body parts.
No, the check for "Do not print selected..." is not selected.
It must be some problem with the layout. Maybe i'll try and delete the layout and re-create it.
