need help with duplicating records
I am having a problem working with duplicated records in FM4 for Mac.
I am create a class schedule. Each record in my DB contains class info including class name, class length, start and end times, etc.
I need one record for each 1/2 hour that a class runs. For example, if a class runs from noon to 2 pm, I need four records, each identical except for the start times (which would be 12:00, 12:30, 13:00 and 13:30). I need a script that will create these records when it sees a class whose length is greater than 30 minutes.
I am trying to use the following script:
Go To Layout [Refresh window, "ShowAll"]
Find All
Sort [Restore, No dialog]
Go to Record/Request/Page [First]
Loop
If ["EndTime > StartTime + 1800']
Duplicate Record/Request
Paste Result [select, "StartTime", "StartTime + 1800"]
Else
Go To Record/Request/Page [Exit after last, Next]
End If
End Loop
Classes are sorted by name & start time. The problem is that some duplicated records are inserted at the end of my sort order, which causes the script to exit w/o duplicating all the records I need.
I have tried inserting a few more 'sort' steps in the script to keep things in line, but it still didn't work for me.
Does anyone have suggestions on how to accomplish this?
-sean
[ October 15, 2001: Message edited by: sean kelly ]
changing my sort order fixed this problem, script is working.
{Emily LeTilla Voice} "Nevermind"
