Problem with 7.0v2 for Developer?
Hi, recently when upgrading to v2 I ran into a problem. On the "Go to related record." script step I use the Show only related records option. This is so I can sort my records by subject. So for example, if I want a list of all the authors in my database I choose authors as the subject in a drop down box hit a button scripted to show only those records and I'm good to go. Only the records with authors in them show up and I
Go To Related Record certainly works. So, if it's not working, the first thing to do is to check the data. In version 7 you can no longer get away with sloppy matches, ie., trailing spaces matter. But that was true with 7.0v1 also I believe. I would look hard at the left side member, the value list value; it may be "Authors ".
If the data is fine, then it must be the Table Occurrence, either the target, or where you're evaluating from. Though, once again, I don't know why the update would be different.
