Printing Problems Please Help..!!
Hey All..
I have a large sales lead database and recently setup a template to print on pre-printed card stock that has 8 cards per page and is a standared 81/2 by 11 page but can only seem to get it to print 6 of the 8 cards properly I have tried ajusting the margins ajusting the spaceing in layout mode etc.. and nothing seems to work either the spaceing gets messed up or things just slide up the page and looks really bad..
Any ideas on how to fix this ever troubleing problem would be greatly
helpful..!
Rob
  • 3 weeks later...
Although you've "tried adjusting the margins", I would probably ask you what you've done and how it adds up....
You can see exactly how many inches (or pixels) tall your records are by using the View>>Object Size box.
Make sure in the layout setup >> printing dialogue you have "fixed margins" set.
Make sure you don't have any Header or Footer part on your layout (unless you've made your margins enough smaller to allow for something to print above the cards).
What's your top margin? What's your bottom margin? What's the height of each record's body?
