Print body layout part only
Hello!
Can someone tell me how you can select to print only the body section in a layout? I want to print envelopes and labels etc. but keep my navigation header on every page.
Thanks for your help and time!
Riky
Hi Riky, you can more easily prevent those buttons from printing by selecting them, then from the Format > Sliding/Printing menu, select "Do not print selected objects" (or whatever the equivalent nomenclature is in version 7).
HTH,
Jerry
AH HA!!! Perfect thanks Jerry...
