Need some help with DDE script function
Hi everyone!!
Could someone show me how to use the DDE script function to call a DTS package(SQL server). Or to call an excel spread sheet.
Thanx in advance for your input and help.
Pat.
  • 1 month later...
If you just want to open excel then use Open URL ("pathnamefilename").
If you want to call DTS then write your DTS script in a batch file, then have Open URL call it. Your batch file may look like this:
"C:Program FilesMicrosoft SQL Server80ToolsBinndtsrun.exe" /N<MYDTS>
If you want to call an excel function using DDE Excecute:
Service Name: Text, Excel
Topic: Text, System
Commands: Text, [run("myexcel.xls!mymodule.myfunction")]
**oops this is in version 55/6 but it should work with 7.
