Locked header and scrolling body
Hi all,
I would like to lock the header section of my layout and only have the body part scroll so that I may dispaly static information in the header section of a VERY long layout. Any tips on how to do this or create a similar effect?
In the layout setup, you could select "View as list" and display
what you want in the body part. The header part would remain stable as you
scroll thru the data fields in the body part.
The downside of that is that you would see a list of all your records
unless you get to that layout via a find script that returns only 1 record.
I'm not sure if i fully understand what you want to do...
Hope this helps.
Dan
Thanks Dan, that's exactly what I wanted.
