Web Publishing Engine Installation Failure...
I am trying to install FMSA 7 Web Publishing Engine on a Windows 2003 Server SE running IIS 6. I get the following error at the end of the installation process:
"Opening Key /LM/W3SVC/1/Root Failed ...default"
my only option is to select "Ok" which then leads to a final screen stating that the installation was interrupted and not successful.
I noticed that the "Filemaker Publishing Engine" service does not appear in the Services Manager. I am unable to access the Web Publishing Console from the http://localhost/fmi/config.
I also took note that the Global ISAPI filter installed by this causes the my app pools on my IIs web server to stop working.
Has anyone else encountered this error. I have scrubbed the internet for possible solutions and have come up empty handed. I also spoke with Filemaker Tech support for about an hour with no success.
Signed,
Unhappy FMP user.
Hmm seems like reformat the server with win2003 and add iis6.
use admin account , install FMS on it than FMAS . Must be same machine, easier to troubleshoot.
If doesn't work drop to win2000 with Sp4 (i think)
