help, When print report, output all script
hello, pls help me...
when i print a table view report from a fp5, it print all scripts of this fp5. only this fp5 file, my other fp5 output is normal. in order to solve this i have to manually change print setting from "copies & pages" to "FileMaker Pro". this time it work, but i don't know why.
tia
It seems that your print is set to print 'script definition' and not 'records being browse'.
Goto File > Print, and make the change in the box. Then when you did that, edit the printing script you're running, click ok and 'replace' the print setup instead of 'keep'. It also sounds like you have it printing directly to the printout without showing the dialog.
