December 13, 200421 yr Newbies I developed a reporting program that gets updated every week and distributed to users. My problem is that I cannot automate building the runtime. Each time I must open filemaker developer and load my *.sav to create the solution. Is there a way to make dev7 compile without user interaction? Developer 6 has this feature but not in 7. thanks in advance
December 14, 200421 yr Where is this feature in v6? I never noticed it... so I guess I didn't miss it when I moved to v7
December 15, 200421 yr I too am all ears/eyes about the feature in V6. How are you 'distributing' the new solution? The reason I ask is that you may not need to create a new solution. In FMD6 you can replace a file in a Solution provided it still has the same name. I'm betting you can do the same in V7.
December 15, 200421 yr Author Newbies Where is this feature in v6? I never noticed it... so I guess I didn't miss it when I moved to v7 When you create a solution using developer tool it generates a <solution.txt> file under /Developer 6/55 folder. Open that file and set Auto=1 then open with developer tool.exe. For the distribution, I use Wise9 to generate a web installer (you need a website host) and distribute link via smtp.
