ascii in a barcode. problems? solution!
I had to make barcodes for articles like:
20314sfsf4
20202020
ab1458-c
etc etc
I used the free 3 of 9 like everybody here told me.
If there were characters in the barcode i had to use the extended version.
I tried and tried and failed and failed.
So i just give the advice why i finally found what the problem was:
1. add a "*" in front and at the end of every barcode.
2. You have to configure your barcode scanner (belgian keyboard etc, caps lock on, enable EAN39, enable ascii. from then on i could read all the barcodes!
Peace!
