Kiosk problem when migrating 5.5 DB
I have a 5.5 solution that is to be updated to v7... The 5.5 version is opened via a script (set to run 'On Open') in a 'launch' DB that resides on the user desktop. There exists two versions of the 'launch' db - one that was included in the bind and one that wasn't. Normal users open using the non-bound launch db and everything opens in standard mode. Public computers open using the kiosk launch db and everything opens in kiosk. Up until now that has worked perfectly - there never seemed a need to maintain kiosked and non-kiosked versions of the databases crazy.gif
Problem: When I migrate the solution to v7, the whole mess opens in kiosk mode unless I open the databases with [Full Access]. Does anybody know of a way (short of redeveloping the whole thing) to 'strip' the kiosk from the migrated databases?
Keith
