FileMaker 2026 Released
Display 10 Portal recs., click down for next 10
Hi all,
Is there a way to display the first 10 portal rows, and then by clicking an up or down button change the group of portal rows displayed. For example, you have the first ten dispalyed, then cick a down button to show the next ten. I am trying to eliminate the visual clutter arising out of the need for multiple scroll bars on a layout with multiple portals.
Thank you,
Don
DO YOU MEAN THIS?
NextPrev..zip
That is exactly what I am looking for, thank you so much for your help and prompt reply. I think I basicaly understand how it works. I will be taking it apart and trying to digest the mechanics of how it works.
Thanks again,
Don
