March 1, 200521 yr Hello guys, Please I need help urgently. I installed FM Server & FM Advanced and configure publishing engine with no problem, suddenly when i want to enter the administration console i am stuck with this "An unexpected error has occurred." if i click on restart publishing engine. I have restarted both web server and console several times in the terminal, i updated FMS to 7.2 and restarted the computer but invain. I am on Mac OS X 10.3.7 Thank you very much for your support BK
March 2, 200521 yr Newbies I have the same problem on a Win 2003 Server. Uninstall, reinstall, resetup the Admin Console but still it's not working. In IIS, Directory Security is set to Basic.
March 2, 200521 yr Author Problem solved, it was a bad setting in my web services (Server Admin). My computer has two IP addresses and the website was set to only one IP. When I chose the option 'Any' IP i was able to connect to the Admin console. Dan, I have no idea how this may be solved in Win 2003
March 2, 200521 yr Newbies I also noticed that deleting the browser cookie created by Web Publishing Administration Console clears up a number of problems. I think it's called 'JSESSIONID'.
