Help!!! with text
A reply to any of the following questions or a No this isn't possible would be equally as valuable as no replys frown.gif" border="0
I am developing a letters and faxes database and have hit three fundamental problems with text formatting, can anyone help with them or one of them?
1. I am using the merge field option on my labels format in the address book. The labels look fantastic until somebody changes the font size in the originating field. This causes all of the text to be formatted as it was entered and not in my default merge field text font.
Is there any way of disabling the font type and size? I have been unable to do this with access privilages.
2. I have a calculation to result in the correct letter layout. Is there anyway of formatting calculated text by the user who doesn't have access to setting field ar merge field text defaults?
3. Is there any way of allowing the user to set there own defaults to text fields without changing any other attributes of the field?
Any help would be fantastic wink.gif" border="0
[ September 06, 2001: Message edited by: Stuart T ]
