March 15, 200521 yr hey guys i have a layout that has a blue background. on top of the background is a large white rectangle. on top of that are multipl eother colored rectangles. on top of them i have transparant text fields. anytime you click on any one of the fields that are transparant you can see through all of them all the way through to the background. is there anyway to get around this? is this a bug or am i just doing something wrong? thanks, Anthony
March 15, 200521 yr Author hey guys i have a layout that has a blue background. on top of the background is a large white rectangle. on top of that are multipl eother colored rectangles. on top of them i have transparant text fields. anytime you click on any one of the fields that are transparant you can see through all of them all the way through to the background. is there anyway to get around this? is this a bug or am i just doing something wrong? thanks, Anthony
March 15, 200521 yr You'll either need to change the color of your background (to white or something), placing a big blue rectange in the background to be your background color, or set a fill color for each field.
