March 15, 200521 yr I've got a bunch of container fields. They fill themselves with an image from one of two fields. The container either gets nothing : "" or red.png or yellow.jpg Then i have a text field which is a calculation.. the calculation is simply the name of the container field resulting as text-- so it gives "", "red.png" or "yellow.jpg" This all works fine.. I have a layout that shows both the container field and the text field, and I see a bunch of graphics with the appropriate text beside the color. A bunch are yellow, and a bunch are red. When I do a find on the text field, if I search for "red.png", it finds all the records that have either "yellow.jpg" or "red.png" in the text field! it should only find the ones that have "red.png" !! and if I search for "yellow" it finds no records !! but they're there, I'm looking at them please help me if you can ! thanks
March 15, 200521 yr Author I've got a bunch of container fields. They fill themselves with an image from one of two fields. The container either gets nothing : "" or red.png or yellow.jpg Then i have a text field which is a calculation.. the calculation is simply the name of the container field resulting as text-- so it gives "", "red.png" or "yellow.jpg" This all works fine.. I have a layout that shows both the container field and the text field, and I see a bunch of graphics with the appropriate text beside the color. A bunch are yellow, and a bunch are red. When I do a find on the text field, if I search for "red.png", it finds all the records that have either "yellow.jpg" or "red.png" in the text field! it should only find the ones that have "red.png" !! and if I search for "yellow" it finds no records !! but they're there, I'm looking at them please help me if you can ! thanks
