data display problem
I have set up two simple FMP files with a single relationship linking them to enable data from fields in one file to be displayed on the coresponding record on the other. This works fine for some fields but erratically in another. In this case the data shows accurately on some records, but on others it is absent until the mouse pointer is clicked on the appropriate field, when it then displays. Once displayed it remains visible after browsing other records and then returning. I have a feeling that it is often the same records which display unprompted but it is not consistent. I have tried reinstalling FMP and I have tried creating an entirely new set of files and importing some original data but the effect persists. On a previous attempt 'absent' numbers were in some cases partially displayed until clicked on. I am working on a Performa 5500/275 and also a Powerbook 5300cs using FMP 4.0v1.
Help please
Go to the FMI web site and download the correct updaters, 4.0v2 and then 4.0v3 for the FIleMAker Pro 4.0 series. See if that helps you.
HTH
Old Advance Man
Is the field large enough to show the data???
Are the data types for the relationship matche fields the same?
quote:
Yes. I did have that problem in which caser only part of the data was displayed as there was space. In this case, however, when I say data was only partly displayed I meant numbers were only partialy formed until clicked on.
quote:
Yes: both are text fields, one of which is a calculation (Field 1 & "
quote:
HTH
Old Advance Man
Thanks for the suggestion. What is the URL please?
Did you download and apply the 4.0v2 and 4.0v3 updaters?
Old Advance Man
