May 7, 200520 yr In FM, if you import a file reference into a container field, you can double click on the container (MAC) and the file reference will open. If it is a PDF file, it will open in acrobat. If a photoshop file, it will open in photoshop, etc. Is there a script that will act the same as double clicking in the container field? LR
May 7, 200520 yr Go to Field [ Select/Perform, the field ] It will work on fields that have Field Behavior set to non-entry if it's a script step. It will not work on those as a single step attached to a button (ie., no script). At least that's what I'm finding.
May 8, 200520 yr It will work on fields that have Field Behavior set to non-entry if it's a script step. It will not work on those as a single step attached to a button (ie., no script). At least that's what I'm finding. Hi Fenton, True. That's because of the general principle that scripts over-ride layout field behavior settings, whereas buttons are constrained by them.
