Label problem!
I have created a mailing label layout using avery 5164 - This is a template with 6 medium size labels to a page.
For some reason, in Preview Mode - information only comes up in the first top right hand corner label. Again, I AM IN PREVIEW MODE - not browse. The label has a text typed directly onto it in the layout with the company's logo / return address - this DOES show up in the labels.
I have other smaller labels (regular letter labels) that work fine - any ideas?
Thanks! Sarah
I have noticed this in the past, as an experement, try reducing the objects to like 1/4 of the label area and reenter peview mode. I found doing this shows all the labels properly, then increase the objects a little at a time to find out where the 'cut off' is.
My findings is that an object may not be over the edge but just close and that stops the proper flowing.
Charles
