May 17, 200520 yr Newbies I need a script that will sort records based on a field and the omit all of the records that don't have that field showing, I can't figure this out!!! THANKS
May 17, 200520 yr "the records that don't have that field showing" By that I assume you mean "records that have no entry in that field" Enter Find Mode [] Set Field [ a field, "==" ] Perform Find [] Sort Records [ a field ] Make sure that the Enter Find Mode and Perform Find script steps do NOT have the "restore find requests" option selected.
