Help with SQL-ODBC statement
Hi you all....
I need some help with a SQL statement. I've setup Filemaker as a ODBC datasource for Indesign CS. The test setup works fine (through Indesign plugin). The only thing that i need to do is use a SQL statement to have bi-directional setting. I must update Filemaker from within Indesign. Therefore i tried this statement:
UPDATE
thx anyway....got it fixed myself....
MAcB
