using Filmaker Pro6.0 Unlimited Upgrade
Can I upgrade to Filmaker Pro 6.0 Unlimited using the upgrade software and licence to upgrade from Filemaker Pro 5.0 ??? or do we need to buy Filmaker Pro 6.0 (or the 5 user version first) Obviously we haven't kept up....
Any help would be a big help....
  • 2 weeks later...
I believe you can, call your nearest Filemaker reseller, to verify just in case.
Regards,
Reg V.
Filemaker Pro Developer
www.lrvconsulting.com
[email protected]
  • 3 weeks later...
Hello upgraders,
before you decide to buy the unlimited version, remember that that version (wasn't it $1200) can NOT be upgraded to Server 7 Advanced. If you plan on using FileMaker on the web a lot, consider upgrading to FM Server 7 Advanced, saving you the time to do everythin twice!
CDML has vanished in 7... you'll need to reprogram anyway in the future...
Hartger
