June 28, 200520 yr I am working on installing FileMaker Server Advanced 7v3 on a Windows 2003 server with IIS 6.0 installed. I have successfully installed the software for FileMaker Server Advanced but when I go to the web to configure the settings and then restart the service I get the error of "An Expected Error has occurred." I have tried stopping the Web Publishing engine and the IIS server without success. I am guessing it is an interaction with the IIS server but I am not sure. Can anyone help?
June 29, 200520 yr Newbies Hi, I just fixed the same problem on a Mac configuration. I had to do the following: Uninstall everything and reboot Install FM server 7 Update it to v7.03 Install FM server advanced Update it to v7.03 Being extra cautious, I rebooted after each install. It's been running quite well for a few days now. From memory I also prevented FM server from auto launching until I had installed the updates for both programs, this ensured that the updates went on properly. Good luck.
