Problem with Calculation field in IWP
In the leading subsummary part, i have a simple calculation field that works fine except in the IWP view. It seems to not display the calculation correctly. is there a way i can setup the layout to do this simple calculation (basically adding page totals) over the web or is that one of the caveats of using IWP?
help .....thank you.
