Publishing Engine Not Responding?
Here's my setup: Filemaker Server Advanced 7.0v3 running on a dedicated machine with static internal IP address (192.168.x.x). Web server & FileMaker Web Publishing 7.0v3 engine running on Xserve with Panther 10.3.9. All is well with the database solution. Ten+ Filemaker clients connecting fine both internally and externally via FileMaker. We need to post some info via web for clients so I set up the FMServer on one machine and the web publishing engine and FM web server on our Xserve which already has our regular website on it.
I can get to the admin console www.mydomain.com/fmi/config. It always says the publishing engine is not responding. They are on the same computer?
I've then restarted the Web Publishing engine via terminal (sudo SystemStarter restart "FileMaker Web Publishing"). Log back into the Admin console and same result (publishing engine not responding).
Note: During the restartart I did receive a HotSpot error:
Welcome to Macintosh.
Restarting FileMaker Publishing Engine
restart succeeded.
Using CATALINA_BASE: /Library/FileMaker Server 7/Web Publishing/jakarta-tomcat
Using CATALINA_HOME: /Library/FileMaker Server 7/Web Publishing/jakarta-tomcat
Using CATALINA_TMPDIR: /Library/FileMaker Server 7/Web Publishing/jakarta-tomcat/temp
Using JAVA_HOME: /usr
HotSpot not at correct virtual address. Sharing disabled.
Startup complete.
Hangup
Anyone have any Idea? Is this a FileMaker Server problem or something I need to adjust on the Xserve. Help would be greatly appreciated.
Figured it out. Adjusted settings for the Xserve.
I have pretty much the same problem you described earlier. When you say you fixed the problem, by adjusting settings on the Xserve, what might you have done?
Can you share your solution? Thanks.
  • 1 month later...
Yes, I am still experiencing the same problem. Could anyone shed some light on these Xserver Settings?
