FileMaker 2026 Released
Windowing Script Problem
I have a “main” record layout and users can click on a button which calls a script to open a smaller window to make certain selections from another layout. (See the attached PDF.)
I then have a button in the smaller window that is labeled "Continue" that does a "Resume Script.” If someone uses the button, all works fine. BUT...
...if they don't use the button and simply close the window by clicking the "X" in the upper right corner of the small window, all SEEMS fine (their selections are made) - except the script is really still left running - as proven by the Script "Continue" & "Cancel" buttons in the Status Area.
I don't want this circumstance to arise. Is there a simple/neat way to prevent this from happening?
Thanks in Advance,
Mark
FileMaker_Script_for_Getting_Compounds.pdf
Allow User Abort [off] might do the trick
SlimJim-
Works great! Wow, that was actually pretty simple. Thanks so much !!!
-Mark
