problem accessing in filemaker custom web publishing when guest a/c is disabled
I am facing problem when accesing through custom web publishing. When i disable the guest a/c in hosted database, and access though browser a http auth window opens and asks for username/password. when i give username/password it does not takes.
Even if i give the administrator username/password it does not takes.
I am using
Filemaker Server Advanced 7
Os: Windows 2003 Sever
Pls help regarding this problem.
Debabrata Pati
Did you assign the fmxslt and/or fmxml extended privilege set to the accounts in question?
yes the fmxml amd fmxslt extended privileges are enabled.
I believe that they are there - however, do you use them with every user account?
yes the extended privileges are enabled for all a/c except guest
Did you try with another browser?
