Scripted Remote volume Connection
Is there a way to have FileMaker automatically connect to a remote volume though AppleScript or other method. I actually am trying to do this on Mac and Win. but thought I would start here. Any suggestions would be most welcome.
Yes,
tell application "Finder"
mount volume "smb://domain;username@servername/share"
end tell
Yep, and on windows you can say:
net x: "127.0.0.1volumename"
Where x is the drive you want to mount the volume to.
BTW ^^ is a send event script step.
What application do I specify?
Is this a Mac question? If so, use Script Editor in /Applications/AppleScript to create the script. Save it as Executable so FileMaker can launch it (rather than opening it as a document in Script Editor).
