March 21, 200125 yr You can have a TownID field in the inscription file that is set to the same TownID as in the client file. Then create a direct relationship to the town file. Then you can display the town name using this relationship. Alternately, you can create a town name field in the client file which is an auto-enter value looked up from the town file based on the Town ID relationship. You can then access this field in the inscription file.
March 21, 200125 yr i have three db: 1 for the town 1 for the client 1 for an inscription for a client --town.fp5 contain two field: town_id and town_name --client.fp5 contain a field town_id with a relationship with the town_id of town.fp5. So at this level, I can obtain the town name. --inscription.fp5 refer to a specific client by the client_id. But when I want to display the town name, i'm stuck... I can only display the town_id. Do you understand my problem :?
