January 16, 200620 yr Hi all, From my solution i'm trying to print on to a paper that contains 3 pre-printed forms(laying under each other on the paper). Form 1 Form 2 Form 3 It's very important that the text prints in the correct place on each form. But the current problem is that the first form is printed correctly but then the second one all text has moved "up"(on the page) a few millimeters and the same on the third form. The layout is printed in "list"-mode (don't know if thats the english term, it's not Layout or Table but the third on and has only one main part on it that contains all the fields that get printed. Does anyone know what the problem is? or have any tips? Thank You!
January 25, 200620 yr Do I understand correctly that you have three 'forms' on the one page? Are these identical? Are you printing data from a single record or multiple records? Do you have any sliding or shrinking fields on the page? Is it feasible to create a layout that matches the pre-printed forms exactly and also includes your fields? You can then look at the layout in Preview mode and check the positioning of all your fields.
