Please help a noobie with a simple relations problem.
I'm sure there is a simple solution to this problem, but I have not been able to figure it out.
I am using FileMaker Pro 8 and I have a database with two tables to keep track of actors and the skits they are performing:
ActorsTable
ActorID#
PhoneNumber
Email
SkitsTable
SkitID#
Venue
Date
Showtime
What I want to do is have a drop down menu on the SkitsTable that will allow me to easily add and change the various Actors for each skit. I also want the ActorsTable to show all the skits the Actor is performing in.
Thanks in advance for any help.
You haave a many to many relationship and you need 3 tables: Actor, Performance & Skit.
In the Actor table you will have fields : ActorID, First Name, Last Name, Address, City, State, Zip, Phone, email, Gender, etc.
In the Performance Table you will have fields: ActorID, SkitID, Venue, Date, Showtime, etc.
In the Skit table you will have fields: SkitID, Skit Name, etc.
Your relationship between Actor and Performace is ActorID. Your relationship between Skit and Performaace is SkitID.
See topic Complex Relationship Help Needed, Post#180289. I posted a sample file there.
Thanks, I thought I would have to use some sort of join table.
I looked over your sample file and it helped, but I am still having a few problems with bringing it all together.
As suggested I made 3 tables:
ActorsTable
ActorID#
FirstName
LastName
PhoneNumber
Email
Age
Gender
SkitsTable
SkitID#
SkitName
Description
Notes
PerformanceTable
ActorID#
SkitID#
Venue
Date
Showtime
Each Skit can have only one Performance (making it a one to one relationship). Each Performance can have multiple Actors, and each Actor can have multiple performances (making it a many to many relationship). I tried pulling event information and actors into the performance table via portals, but things did not work right.
The end result I am trying for is to have one layout that lists SkitName, Venue, Date, Showtime, Description, Notes, and lets people add up to 8 Actors to it via pop up value lists. What am I doing wrong?
OK that is different from what I thought. Change Performance table by removiing ActorID and add PerformanceID. Make a join table between Actor & Performace using the key fields ActorID & PerformanceID.
A portal in Performace looking at the join file will allow you view the actors.
