April 7, 200620 yr Newbies Can I upgrade file maker 5.5 pro to 7 pro by using the Filemaker 7 pro CD? How can I convert our filemaker 5.5 pro documents to 7 pro without losing data or getting errors? Is there a way to automate the process? What would be the best way to upgrade our department’s Filemaker 5.5 pro software? Thanks!
April 8, 200620 yr you would be better off upgrading to FM8v2. There are less bugs with any new FM version, you can open and convert all your files, with data, in one step But, conversion is not completely seamless. Be sure to read the conversion whitepapers available on the FM web site. The converted solution will require some fixing, e.g. script steps, user accounts, & file references So, be sure to test the converted files "off line", then re-import the current data when ready to go
