Repeating Contrainer Field + Picture problem
I have never really dealt with container fields before and I'm having some problems understanding how to insert pictures into a repeating container field.
I want to insert 3 pictures, a red box, a yellow box, and a green box.
I have a To Do List, and want to display a certain picture next to (or within) the portal depending on when the item needs to be completed.
I created a new repeating field in my To Do List table, with 3 repetitions. Do I need to put all three pictures in each record, or do i need to make a seperate table that just has one repeating container field?
My main problem, however, is that I can't figure out how to put 3 pictures in one repeating field.
Sorry for the rambling. If you need any clarification, don't hesitate to ask.
Define a container field with 3 repetitions and store it as global,then make sure all 3 reps are set as visible. In browse mode paste or insert your images one each into each repetition, and then you can make a calculation field with result as container, and call the appropriate repetition according to your criteria.
Hope this helps - see the file.
Cheers, Muzz
Container.fp7.zip
