Upgrade to eliminate 5 record max view over web?
Hi everybody,
Does anyone know if there is a version of FileMaker that I can upgrade to that will bypass the limitation that lets you only view 5 records at a time when you are viewing them thru a web browser from a locally web published FileMaker Pro 7 database? That 5 record limitation is killing all my web publishing plans.
I'm about to put in a recommendation for some FileMaker Pro upgrades and if either Advanced or Server can do this, then I'll get one of those added on. I tried getting an answer from FileMaker, but they replied and asked me to call their technical support. I just don't have the time or the patience today to sit and listen to musak for 20 minutes. So if anybody knows...that would be sweet.
Thanks!!!
For FMP 7 and FMSA 7, make sure you have the latest updaters, including the separate 7v3 IWP update in the case of FMP. The limit in the most recent version of FMP7 and all versions of FMP8 is 25 records in list view and 50 in table view.
