Printing Problem With FM Pro 8.03
Since upgrading to 8.03, Filemaker Pro crashes every time I invoke the print menu. Page Setup is ignored. Is there a workaround other than reinstalling FM Pro 8.01 which worked fine? Thanks.
Something is wrong at your end. FMP should not be crashing like that.
Change printers. Change printer drivers. Re-install FMP. Check the file for corruption.
But don't go back to 8.0v1, it had some bugs in it.
Maybe download the 8.5 trial and test with that.
