FileMaker 2026 Released
Converting to UK system settings?
I am in the process of modifying the stock Business Productivity Solution from Filemaker. This was made using USA date and system settings. Is there a simple way I can convert all of the databases in this solution to UK format? or do I have to change each date field manually?
I have FM Pro 8.5 Advanced, if this makes any difference.
Thanks in advance!
I worked it out!
I saved copies of each database file as clones. This set the system settings of these cloned files to my UK format when I opened it.
I hope this helps others.
