do script while script running?
What would happen if an AppleScript called a do script command to trigger FileMaker Pro but FMP was already running a script?
If bad things how what do I do to make sure FileMaker Pro is idle before I tell it to run a script?
  • 3 weeks later...
Your AppleScript will time out while waiting for a reply.
Using a "with timeout" construction in AppleScript will let you know FileMaker is not ready.
The rest is a catch-22. You cannot ask FileMaker if it's busy, because it's busy.
